- Sticky clutch pedal
- Front end design swap on 1979
- Thoughts On Axles?
- Truck stalls, then shoots gasoline up and out of the carb! HELP!
- Horn problem-always on, may involve steering wheel
- AC for the copper truck
- 16 Inch Rims?
- 1979 Fuel Filler Neck Housing Search
- 1978 Ford F150 I call Brutus.
- Need A New Roof
- Dentside F-150 rear window angle, same as '80-'96?
- What is this on my '75 F-250 fuel line?
- Axle 6cyl question same as V8
- Crown Vic swap - So, 15" wheels fit after all.
- what 11" brake drum to use with 4.5 bolt pattern
- Parasitic draw after 3G swap
- Indicator lights come on with turn signals (?)
- new addition to stable 1978 F100 ....need vin decode
- How much would an original 460 intake manifold be worth?
- Highboy Problems, HELP
- Door gasket problem
- I'm new!
- Radiators...o the joy
- Column to floor shifter conversion or "Its not easy looking cool"
- Engine out, need to turn it over
- In-Line PS Filter
- MC Cap and Gasket F150 4x4 1977
- Wiring. Specifically Gauge feed harness
- 400M dipstick hole
- Dupli-Color Vinyl & Fabric Coating???
