- truck heats up @ idle
- p brake problem solved
- Distributor Question and FYI..
- place to get transmission hump cover?
- hook tool?
- 360 starting problem
- retired my 78f150s/c and found nice 79f150s/c wondering about swaping dash metal
- Giving up the 4x4 for a sweet 2wd.
- best 4x4 '73~'79
- Vacuum Advance
- front dana 60 worth
- choke plate pulldown spec
- highboy
- Dana 60 Rear Torque specs
- dana 44 front
- factory hoses
- temp gauge in 76
- Changing to a newer dash in a 73
- need bumper height: 4-6" lift/33-35" tires
- 75 ford f100 i think
- Wantin to keep runnin...
- Homemade Front Bumper
- Stock Exhaust Description 79 F250
- Power Steering Problem!!!
- Crew cab + extended cab conversion...
- Removing Cab mounts from frame
- stalling question
- Swap a Motor?
- Shortening a frame.
