- 54 f 250 on a 78 f150
- trouble with a/c ducting
- F150 leaf sprung D44 spring perch spacing
- F350 - but not a SCS
- Running rake lights?
- okay, dumb tail light lens/bulb question...
- Smog hook up??
- blk/wht tu tone paint scheme ever used
- 460 only fires on 1 cylinder
- How much lift
- Ask the Ford guy.......
- fuel tank
- Ready to hook up original Ford Radio...question #2
- Ready to hook up original Ford Radio...question #1
- Share your Temp Gauge readings to help calibrate to Deg F numbers.....
- What is considered mid-1977?
- 79' stepside street rod
- need timing help
- need Wisdom on big block carb match.
- 16" rims on 78 f150
- Factory C6 73-77 F250 4x4 Highboy
- 79 250 2wd to 4wd Conversion
- Good day at the Junkyard
- COMPLETE 77.5 to 79 conversion
- guage cluster
- lock hub replacement
- Hood lock question
- water going somewhere
- New to fords... lift question
- Lug nut torque specs
