- It's cold and some vacuum lines are standing between me and my heater
- 1979 Ford F250 Steering
- Np 435 shifting pads
- Need advice on suspension work. photos in post.
- Cold Idle Issue
- 351 w flywheel question
- Accelerator Pedal differences
- 1977 F-150 Custom Transmission ID & Questions
- LED Headlight Recommendations
- Fitted bed rail caps for a '77 F-150?
- New 460 Timing Cover Mystery Studs
- Hose from Throttle Body to Valve Cover
- Truck fluids
- Hooking exhaust to stock exhaust manifold
- Dana 60 Disk Brake Conversion
- Are our side windows "glued" to their track brackets?
- Basket case buy- questions
- 330md or 360
- Stripped thermostat housing at block need advice
- BRAKE BOOSTER PUSH ROD BOOT QUEST
- Remote start?
- '76 Midnight Blue High Boy Restoration thread
- 1974 F-250 Crew Cab Restomod build thread
- Carburetor?
- F350box fit on highboy?
- Using vent for return with Holley Sniper on 74 F250 tank behind seat?
- Emergency brake replacement question
- I'm hooked. '76 F100 - PICTURES ADDED
- 429 in a ‘77 Highboy - Pro or Con?
