- Nice 79 F-350 on ebay.
- ford axle or dana??????
- rearend swap
- starting a parked 1977f-150 help
- how do I tell?
- kickdown linkage problem
- axle id code
- Oil Pressure
- Lift Kit???
- girl needs help with truck
- ’72 LTD rotor/drum swap on a ‘73 F100
- finaly found ignition problem!!
- 79 super cab frame shortening.
- lowering suspension on 79 f350
- Ex-U-Haul
- best modification
- Brake Lines and Such
- Header Problems
- Hydraulic cluch in a 76
- Drip rail trim on cab
- Emissions necessities and options?
- oil pressure sending unit
- Changing axle ratio
- Truck "jerking" violently and didn't want to run... where to start?
- sell or scrap
- Single Cab sound system
- need some picture help
- Replacing bushings -- is there a complete kit
- need help with motor,trany,and transfer case set up
- weird steering
