- what makes an '85 4x4 a "sport"?
- will a 87 trans 460 fit a 86 460 help me plzz
- timing question after installing HEI distributor
- I am determined......
- My 1984 F150 project has decided to run me crazy!
- Swapping over radio and clock
- Where is the bleeder valve on aftermarket slave cylinder? (83 F-250 460 T-19)
- How do you set the electric choke on an edelbrock performer
- Fuel lock ring help!
- Chasing a demon...
- Motorcraft 2150 choke conversion
- Removing 2 piece Driveshaft-1980 F-150
- Removing Rear Brake Drums-1980 F-150
- will a 87 bellhouseing fit a 86 truck
- swapping rear outputs on a np208
- windage tray with a stock 85 pan
- Inline six 300!!!
- JY Score!!
- Overheat/Running w/ out Thermostat
- '86 to '81 parts swapping?
- strange problem with my truck
- Different AC compressor
- 1985 F150 Not Starting Need some help
- 88 4.9 died no start
- Park does not hold the truck (AOD)
- Body mounts are tired!!!
- Engine Swap Question
- dsII ballast resistor
- '84 4.9L Won't Idle
- spark plug gap for 1985 f250 460 engine
