- after market EFI systems
- Vacuum Line problem!
- 1986 truck bed
- BRAKE PROPORTIONING VALVE
- HVAC vent/door problems (WAS: My 86 F250 is haunted)
- Pittman arm shaft bearing
- 1986 F350 Diesel/Auto Any Good?
- spark plugs
- rear leaf springs
- Steering wheel repair - gone bad
- Bed Bolts from HELL! Help
- RPM vs MPG (and everything else...)
- Carter 1BBL Rebuild - Looking for Specifications
- Busted Fuel Tank
- get my truck repainted or do cummins turbo diesel conversion
- How do I calibrate my gauges?
- make 1 good truck out of 2
- hooking battery back up to see smoke?
- Steering column mounted controls.
- Duplicolor Spray Bed liner ... on a DYI Dash top?
- Let's see some lifted 80's
- Flareside alert
- Need a glove box lock? Check Dodge Vipers.
- 85 f150 4wd bad engine
- starting my '86 f150 4.9L in the cold
- Original wheels?
- 5 Speed Swap.
- NO BRAKES
- Starting issues on 86 ford f150
- Meyer E-47 Plow - too tight!
