- Headers/exhaust for a 1983 extended cab w/351w?
- Camshaft question
- CASTING NUMBER QUESTION
- 1983 460 belt squeel issues
- Did TFI Dizzy & modules EVER come with Carbed motors?
- Need brand new stock Intake manifold
- 82 6cyl Coolant Leaking & No Heat
- Ignition Wiring Problem
- Old red is leaving
- Skip White measurements differ, is it an issue?
- 86 f150 rear brake line fitting size
- Crew cab doors
- Fuel supply issues f-150 1986
- 1986 f-250 dip stick
- Valve cover vent-to-carb. reroute?
- built motor and distributor problem
- Will this work safely?
- 9w paint code
- Dana 50 TTB Diff Drop Brackets?
- Where do I find the "fasten belts" "brakes" etc. plastic pieces for the dash???
- I DONT UNDERSTAND. truck grinds in 1st 4 gears and wont enter reverse
- Wiring Help..
- Fastener Documentation
- truck wont drive unless its in 4x4low
- starter sounds like the gear is striped~help please
- Thoughts On Fuel Pumps (electric in-tank)
- Backwards: 351 H.O. to 302
- 1980 vs 1981-86 Ignition Lock
- Need advice on missing components on truck
- 460 C6 tranny vacuum module stripe?
