- what lube to use?
- PO trashed the carb - replace?
- Hub shifter needed 1985 F150
- what rear end ratio
- Ordered new distibutor...supplier sent a different part #
- Stuck Tailgate
- Passenger side front shock problem
- Need help asap. Trying to swap intake manifolds, and old one is stuck
- Ford F-150 and Ford 2-50
- Sudden loss of oil pressure!
- 1986 F250 ex cab Long bed with a 460 (help?)
- Extended Cab on 133 Inch Frame?
- Steering column swap
- Driveshaft yoke question...
- Vinyl Paint ???s
- 4.6 In one of our trucks...?!?!
- Front Hitch?!
- Transmission and rear end questions
- Positive Battery Cable Very Hot
- Transmission Fluid Question
- Inherent problems with 1984 Diesel engine?
- Ticking issue?
- four link rear suspension for F150
- fuel pump - total failure?
- My exhaust question
- Help!!! My Truck Won't Start
- well still working on the problem with the starter but now....
- Year of the V6
- 86 Heater core replacement. A/C vs. non A/c?
- Which years r compatable
