- 1986 5.8HO Spec's
- 1984 F150 Need new wiring Harness
- 302 to 351w swap
- past 2k rpm, truck hesitates
- wheres the redline?
- 85 F250 6.9
- 81 F150 300 has no power & hesitates
- duraspark swap
- replacement body pannels
- 3 on the tree ....sometimes
- Exhaust size?
- 84 F150
- cab replacement
- those plastic vacumn lines
- Duraspark Conversion And Emissions Question- Arizona
- 1982 F 150 4X4 - loose steering
- Rain water leak onto pass side floor
- 351w to 429 swap
- 86 F250 7.5 choke coil
- 86 F250 width
- 86 idle problems and noise
- rear lights aren't working
- msd 6a
- msd 6a
- Failed DEQ
- I6 swap to a 351 big block
- Cargo light for 86 f150
- Module I think
- 84 F250 front axel- swap to solid axel
- Bad catalytic converter?
