- 1985 very intermittent cold no start
- truck dies when idling
- '86 efi 5Lt Electrical problem????
- air cleaner missing vac lines
- Rear end issue
- Intake
- Question About Fender?
- Need help with electrical problem
- 1988 efi six into a 1986 f250 issues?
- Relay for horn on 85 F150 location?
- 82' 351 Engine suddenly lost 30% power
- Fast idle always
- Tank switch location?
- EGR block off plate?
- Double Check Me Please
- Brake Problems!!!
- wiper switch on 84
- Tack Pegs out when A/C fan is on high.
- Is my alternator dying?
- grinding noise in front diff
- Anyone used Lucas Oil Stabilizer?
- gas F350 2WD rearend on diesel f250 4WD?
- driveshaft swap?
- Facotry Tach? Dash woes?
- 86 UPDATE v.pics
- dropping the oil pan: urgent
- Steering knuckle camber install
- Hard Decision but need an Answer.
- 1985 Ford F-250 Diesel.....just got it.....now what?
- I have started the rebuild...
