- Converting EFI to Carb on 1986 ford f150 5.0
- 85 f350 6.9 loss of power
- Switching from Column shift to floor shift?
- run engine with trans off?
- Fan just works on High 85 F150
- Fuel pump fuse/ Wiring problem?
- f150 5 speed swap
- '84 F150 302 V8 Vacuum Hose Diagram?
- 1986 hardly any brakes
- 1984 f150 axle swap
- 1986 460 c.i. - Vacuum Diagram
- signal switch
- No pressure after master cyl and brake line replacement
- Should I get this 86 F-150?
- injector pump
- 86 Dana 60 brake caliper bracket
- runs great till it warms up
- Balance question.
- Just turns over
- 81 F150 what autotranny is in it?
- Rear antilock light on??
- Shopping List for Rebuilding My Front End
- Almost Overheating at lights in Traffic.
- '86 F150, 6cyl, auto - $1995? Good buy?
- Aftermarket parts-300I
- minimum amps to start
- 5.0 air intake
- Door Swap Questions
- EFI conversion
- Shift light and 4x4 light
