- Water Entering at Lower Lift Gate on 08
- exhaust flex pipe cracked with 51,0000 miles?!?!?!
- Just bought an 08..so far so good.
- Is the Escape 5-speed a Mazda trans? Just put a deposit on one...
- Brake pad life
- 2004 Brake rotor removal
- pcv vavle
- 2005 transmission
- Cylinder 3 misfire
- New here. EGR flow insufficient Help!
- 2007 headliner removal
- What oil weight are you using?
- Help with lower control arm please
- 08 gas tank sloshing sound
- 2008 Escape V6 Limited Break Question
- 02 Escape, help
- Escape 2008 steering wheel radio stations
- Considering an Escape
- Best wax for an 08
- 2003 Escape coolant light
- Battery light
- Replace LH front wheel bearing 01' Escape
- 2003 escape starting problem
- Cruise control quit
- July black metallic 08 report
- ignition key won't turn
- Coil spring spacer, block
- Escape Just Wont Start
- 2002 ABS/ Growling sound from front right
