- lights for dashboard
- cost to tune up 97 ford explorer 4.0 SHO
- Front Brakes and Jacking
- Plenum Gasket Set
- 94 explorer gas smell and other
- 02 Explorer SUV auto 4x4 problems
- Code PO 442 >> Evaporative Emission Control
- 2008 Eddie Bauer V8 97 Explorer XLTV6
- 05 Explorer rear brake help!
- 02' Front pinion seal
- Engine swap
- Growling
- Fan Fan Clutch
- Tranny Drain/fill plug
- Exhuast tips on newer Explorers?
- blend door actuator FYI
- Throttle body cleaning?
- 4.0 OHV pressure regulator
- Easy Start, No Power - '99 Explorer
- 97 Explorer transmission fit
- Coolant Leak '06 Explorer
- 2002 Explorer Sport Brake Issue
- What is the trick for keeping them on.....?
- 1997 explorer transmission
- won't idel
- It Rumbles
- HO2S problems entire circuit
- odometer display lights intermittantly
- high idle
- Replacement Plugs and Wires for 99 Limited
