- 1994 Ford Explorer... Need Advice?
- New Guy with a few questions
- Radio Sound not working
- day time running lights
- Towing a 91 explorer
- 98 explorer exhaust,sohc
- 99 explorer reverse slipping
- 04 mountaineer brakes
- 95 Explorer Dash noise
- Quick Fix for a sluggish 98 V8 Explorer
- DANA28 axle or DANA35 axle?
- Fenelon Falls Area Off Roading
- Ignition switch recall
- Changing ring gear on a 91 explorer
- Remote Car Starter any suggestions?
- Tire Pressure on 02-05 models
- Problems With 4x4
- instrument panel lamps
- Headlamps stay on! Help!
- 4.0L SOHC Plug & Wire Change?
- 1992 Explorer Trans case shifts hubs don't lock
- 97EB 5.0 engine misfire
- whine/siren noise after I changed the hall sensors/speed sensors on t-case
- sensor
- A Few questions with a '96 Explorer 4.0L
- K.N air charger tripping check engine light
- blend door anyone?
- 01 SOHC 4.0 cold poor idle, no code, good IAC
- Back window on '01 sport trac
- electric fan or exhaust for mountaineer??
