- 1992 Explorer will idle but stalls
- MPG using E-85
- Vent cuts off when engine pulls hard
- 02' Explorer Nosie from front end
- Pesky "Check Gas Cap", Need Help
- Looking to buy Sport Trac need advice
- Check advance trac, ABS, 4x4 warning lights
- Rear power windows
- Confused
- Parking Brake Problem on 97 Explorer
- P1507, P1450, P0171
- Water Leak
- 2002 Explorer Shift Engagement Delay
- Check Fuel Cap Light
- 5R55W Overdrive Servo Replacement.
- New Owner, Need help!! 4x4 question
- Rear end noise (any idea)
- Inner Tie Rod Replacement
- 2002 4.6 4x4 flywheel cracked?
- Where does this go???
- 04 Explorer Rearend Howl
- Wheel Hub Nut
- Disable Factory Alarm - 1997 Explorer
- 01 Explorer Stalls When Warm
- ABS Light on
- Not sure how to.
- Oil pressure sending unit location 2001 ex
- Rear interior fan makes noise
- 97 Ford Explorer Oil Pressure Problem
- 94 A4ld Work In1993
