- 95 explorer trans shifting problem
- '02 Explorer Reman Transmission installed -- Forward is fine, but no reverse
- 95 explorer 4x4
- 96 explorer no start
- 1996 Explorer 4.0 temp gauge movement
- Cracked Head???
- Cruise control Buttons
- '00 Explorer questions
- 2002 Explorer erratic fuel gauge Please Help!!!!
- Regular or Synthetic??
- Mercury mountaineer rear window trouble
- Help! Everything is 2nd gear
- 07 Rear Power Folding Seats
- Weird electrical problem, 03 Explorer XLT
- intake valve is full of antifreeze...
- Exploder died
- What ARE these pipes??? HELP!!!!
- explorer not down shifting
- 97 explorer power window
- Oil reset on 03 mountaineer
- Calling Engine Gurus--Explorer Info
- Brake Sticking
- 4.0 sohc oil pan
- Headlight issue
- gear shift light
- Does coolant pass through 93 Explorer’s timing chain cover to the water pump?
- 97 Explorer Key Fob.
- Torque specs needed for driver's side wheel hub
- !996 Explorer remove instrument cluster
- 5.0 into 4.0
