- looking for Ex, what year would you buy?
- 2000 Ford Explorer 4.0 (x) engine check engine light on
- Rear Bearing Replacement
- Oil filter leaking?
- 94 Explorer New Clutch now has rough Idle
- 2004 mercury mountaineer real bad vibration
- Shudders a bit on takeoff
- Factory Remote Start PATS Key Question
- Chance to buy a 96 explorer cheap worth it to buy it?
- Idle Drop
- Cruise control R&R - FYI
- rear end
- 97 ford explorer
- diff leaking UT explorer
- ABS light on - but cant read code!
- cant find lift kit for 96 explorer
- Sport Trac Blower Motor Resistor Location
- Friends 97 explor trans
- Engine didnt want to downshift, "Popping" sound
- Camshaft position sensor
- Shock replacement
- transmissions?
- p0340 code
- FYI 1997MM AWD Transfer Case
- missing while accelerating hard
- 2002 Explorer Sport lift options
- looks like it is thermostat time 98 mountaineer
- Oil pan RTV?
- Blue smoke on start up...2009 mountaineer
