- Rough idle after throttle
- What to look for??
- OK, Whats Happening Here???
- OFF TOPIC- this is for you engine tech guys
- IC pipes
- loss of power and rough idle
- Need help on fuel pump problem???
- Question about TT mirror wiring
- HArd time starting
- Truck wont start
- headlight swap issues
- Opinions on Striker I power module #64065
- Engine smokes white/blue start up and idle
- Shut down and be and had to take a ride on a Roll Back.........
- 2003 f250 7.3 needs help
- New Valair clutch question?
- Slight miss at idle.
- engine exhaust gas temp
- OT: Who wants OEM FOG LIGHTS!!
- ICP sensor
- Loud Whine When Brakes Are Pressed? Cause?
- Need ignition help asap
- LL injector by ser.#
- tuners/code readers
- 2002 7.3 sluggish issue
- old FPR
- headlights
- Center pin on the 7 way blade not working
- need advice for high EGT's
- little new bling for the old XL
