- SOLVED! Need quick suggestions: Alternator only 11.7-12.1v. Was no start
- Switched to red ELC now getting small leaks
- fuel in coolant
- EMERGENCY how to keep block from cracking
- Strange Brake problem? Help?
- EGT temp check
- Confused about Antifreeze
- Why is engine heater going bad?
- Merry Christmas-Happy Holidays Everyone!
- Transmission - Mechanical Diode question
- My first real truck
- 4R100/5R110 fluid change
- Cord Management
- Super Duty 20" OEM Wheels
- FIXED - Need Help / Info - Possible bad fuel pump - No pressure
- Bought a 38R but got a ?
- Wheel bearing problems
- RDP 66mm GTP 38 conversion kit.
- Can't pass Calif emmisions
- Fluid time
- Replaced HPOP with new from oriellys started but died soon after.
- DP Tuner cutting out
- eont start when hot. Cranks. No start sometimes stalls at idle
- Boost control advice
- To paint or not to paint... Opinions
- Black CPS died (finally)
- 20" wheels on a 1999 F250 Super Duty
- Turbo rebuild help - heat shield on center carrier
- New Guy with questions? Engine stalls & dies
- Thanks FTE, RiffRaff Diesel and Fletchers Diesel Shop, oil leak fixed.
