- New to diesel oil change questions (overfill concerns)
- OEM Fake?
- Viton Torque Converter Hub Seal
- UVCH odd ohm readings and behavior
- Can installing a chip cause a PCM to get fried?
- Shell Rotella T6 $10.98/Gallon @ Pep Boys After Rebate (Limit 2 Gallons)
- "Stinky Spike" on Early 1999 7.3 P1282 after a hard pull and deceleration.
- Battery Harness replacement
- 99 F250 4x4 Bully Dog 3... Truck has no power rough at idle
- Parking Brake Pedal Assembly Refresh
- Required vehicle sticker in door?
- Vacuum and the Knuckles
- coolant shelf life
- What is this? Oil hole?
- ZF6 to 4R100 swap in 2000 psd
- Not Another Oil Thread
- Oil in coolant?
- AFE filter cleaning?
- The Black Pearl, a 2000 f350 project
- Frankenstinky's next upgrade - The padded cell.
- Ujoints or 4wd?
- Injector time 160/0 vs 180/30
- facebook find!
- Overhaul Plans
- Transmission cooler lines to radiator?
- UCVH - While Im Here, What Else Should I Look At?
- For the Full Syn Oil guys
- Icp issue
- fuel pressure sensor CTS 3
- Rough start up when warm…
