- Clutch pedal - something broke and went to the floor?
- What years interchange--truck bed-- from a 1995 F150 Ext cab short box-dual tank
- shimmy at 40 to 55 MPH 1995 F150 Ext cab
- Sheet Metal
- Check Engine...Always
- Front springs????
- more power on 4.9 Efi
- 4.9 efi idles too low?
- Lightning EGR spacer needed
- Idle re-learn procedure for computor
- Bumps Wha????!
- 1988 302 MSD Distributor
- 1988 302 TPS Installation
- truck does nothing
- Front Brake Problem
- Front wheel bearing adjustment
- beeping box
- New springs, new vibrations.
- How many O2 sensors?
- '88 302 stalls when I press the gas pedal
- which tranny do I have?
- going after an 89 F250
- 89 F250 4 inch lift 365/65R16 ?
- up liftin my 93 F-150
- F350 front end install in an IFS F250
- fuse size for 90 F150
- 89 Octane In a 5.0
- Throttle position sensor
- Transmission help
