- replace a.i.r pump with air compressor?
- will removing cat from exhaust mess with computer?
- 5.0 to zf5 swap?
- Newbie to Fords
- What type of Borg Warner transfer case do I have?
- hard buck on take off
- gas or diesel ?
- fuel tanks
- HELP: Got fuel building up in the crankcase...
- 92 F-150 OK to unplug knock sensor?
- High pitched squeal/brakes
- Weather Stripping and Seals
- Loss of Power
- Help no oil presure after oil pan change and rear main seal
- P1351 and Knock under load.
- Glasspacks on a 460?
- 95 F150 Mileage?
- Swapping 1996 F-350 CC onto 1987 F-250 Ext Cab
- Banging noise
- rough idle, then high idle. Going Insane
- wheel spacers for my truck???
- will f250 rear leafs bolt right up to f150 leaf mounts?
- gas milage help 94 f250?
- tool boxes
- 92 F150 - Problem with trans EOD4
- low budget 5.0 build advice...
- Missing Interior? w/pics
- 302 rockers on 351
- Pulled a heavy load now trannys dripping??
- 1990 Ford 460 FI major power loss
