- 97 Expy Side Mirrors in need of an Exorcist!
- Difference Between Spark Plug
- IAC, MAF or something else?
- AWD doesnt work but 4h & 4lo does.
- 97 Expedition rear axle seal
- Anyone have the 2002 Shaq edition?
- 99 Expedition intermittent air suspension leak.
- Front wheel sqeal/sqeaking 2000 4WD Expedition
- 2000 5.4 Dies when cold/start wont idle
- Wood Grain Dash trim kits??
- fuel injector size
- In need of Tips on removing iac 99 expedition under firewall
- 03 vent problems
- 02 Fog Light Mod
- GEM 240 testing/replacemnet - wiper controls
- Rough Idle When Warm
- 01' expedition odometer backlighting failure
- 97 LLS Shock Leaking
- Headlight swap.
- New to expys
- 99 Expy driveline ? tapping/clicking ?
- What to do to be able to tow 8000lbs?
- 03 EXP 5.4 rough idle - New User
- Any advice on a P1815 code--4WD Mode Select Short Circuit to Ground??
- heated seats
- CEL on but no codes?
- 97...effect of bad/clogged injector
- Does ANYONE know if you can replace the heater core in a 98 without removing the dash
- tire question
- Front 2 inch receiver for 03
