PDA
View Full Version : '80-'86 HOWTO's
Pages : [1] 2
  1. HOW TO: Changing Carburetors and Making it Work with an AOD
  2. HOWTO: De gum your ignition lock mechanism.
  3. HOW TO: Swap AMP meter to VOLT meter
  4. How To Get Rid Of Smog Pump Bracket
  5. HOWTO - Instructions for resetting odometer mileage
  6. HOW TO: Replacing Power Window Motors
  7. HOWTO - Change the Rectifier in a 3G Alternator
  8. HOWTO - Use Some ABS Pipe to Pull Front Cab Mounts
  9. HOWTO - Add LED Lights
  10. HOW TO- restoring your mirrors
  11. HOWTO - Refoam car speakers for FREE
  12. HOWTO - Complete Guide to Ignition Conversion (DUI) , Comptuter Delete, Emissions
  13. How To: Headliner
  14. Contents of '80-'86 HOWTO's - what's here
  15. HOWTO - Low Budget Dashpad Repair w/pics
  16. HOWTO - Starter motor replacement 101
  17. HOWTO - Repair Locking Hood Release Cable
  18. HOWTO - Quick Reference to change heater core (without AC) and/or thermostat
  19. HOWTO - Rear Window Replacement
  20. HOWTO - Front clip swap
  21. HOWTO - Steering Box Rebuild
  22. HOWTO - Brake Caliper Replacement
  23. HOWTO - Adjusting Hydraulic Valves
  24. HOWTO - TTB (Twin Traction Beam) Frame Bushing, U-Joint Replacement, etc.
  25. HOWTO - Aluminum Wheel Reconditioning
  26. HOWTO - Firewall Flex/Crack Repair
  27. HOWTO - DSII Conversion (swap from TFI or EECIII / EECIV to DSII)
  28. HOWTO - 3G Alternator Installation
  29. HOWTO - 81-86 gauge cluster in 80 model (gauge models ONLY!)
  30. HOWTO - HOW TO CONVERT YOUR FACTORY LIGHTER SOCKET TO BE KEY-SWITCHED
