- Has anyone here used a glowshift gauge pod?
- custom resistor mod idea and ?'s
- ECU removal- am I missing something?
- Hpop?
- engine shuts off while driving (not cps i changed it)
- How's your trailer backing skills??
- TW selector switch question
- Wow!!
- replacement thermostat housing source
- Instructions Please
- Testing for vacuum leaks
- Replacing ipr o-rings
- What is the best disk brake pad?
- FPR messed up maybe???
- engine or clutch causing vibration
- need a new turbo
- flywheel
- Rear end Hum-mild whine
- cel light
- what parts make PSD work?
- Need help!!!
- EBPV Switch
- Turbo questions?
- labor rate for doing injectors?
- Turbo Lag & 10k,15k, 20k mod...
- please read need advice quick
- vacuum pumps??
- Removing Factory Air[Filter] Box
- what is it?
- Head Gasket?
