- Found the problem!!!
- Interior $3450 later
- Tractor Supply Rotella T6 5w40- $18.99
- head studs, etc.
- Valve stem/valve lock questions
- Oil Cooler and Oil In Antifreeze
- Knew it was too good to be true...
- Mods for 96 7.3
- What size is this?
- clutch replacement
- surveying the crowd on rollover with youtube!
- So Mad
- Anyone know No-Limit tunes?
- Fuel bowl leak, what sensor is this?
- new rockin development in squeaks and chirps!!
- Winter Storage Tips?
- Centurion 6 Door
- Rough running truck
- Holy smoker batman
- 95 PSD value?
- UPDATE: Crank/No Start...
- Leaking Oil Pan Gasket
- Alcohol Injection Systems
- 1990 gas to 1995 PS conversion questions
- Remote start
- Off road led lights
- OEM bearing part # needed
- Quick Question - "Sig Rtn" (PCM Pin 91)
- Injector plug question
- recommendations for clutch set up
