- Turbo upgrade for towing
- Idle fluctuation when up to temp?
- Triax Oil - anyone use it?
- 7.3 surges and loses power
- Anyone replace vacuum pump bolts with studs?
- 7.3 Occassional Misfire (2 cylinders and other times 4)
- Bypassed RABS - proportioning valve?
- Boost leaks!!
- Cooling system overhaul - water temp still not getting above 170 deg
- Reproduction radiator support
- 1996 F250 Transmission issue
- '95 F-350 A/T shifter cable
- 97 f350 diesel
- How to polish/shine F350 tailgate???
- Kinda a odd question
- Advice needed on side steps
- 1997 Ford F250 7.3 crew cab powerstroke - tank removal
- 96 F350 front alxe
- Slight rough idle 7.3
- Question on Rotor Removal '97 F350 Warn Premium Hubs
- 97 7.3 water pump pulley wobble
- A lil help for clifford
- 10.25 pushed to the max. What's next?
- 1997 tranny swap
- Requesting expert help!
- E40D to ZF5
- Water pump pulley
- 10k MOD?
- 96 f350 radiator support
