- EGT temp
- Ford got me by the balls
- Maxi fuse #13 blown ?
- Cold Transmission slip
- Wheels
- Which Mod to do??
- glowplug relay
- i have injector oring install questions
- Fan Shroud Removal
- For those of you with stacks.....
- head studs
- frantz by-pass
- Bad Idm?
- Here it is guys...
- Cold Turbo Sound???
- Battery cables
- Anybody need an early 99 intake spyder for IC?
- Remote start tach wire location?
- 95 7.3 start up problems
- New here...
- injector removal
- truck stranded. turns over- no fire. ideas?
- Boost gauge ???'s
- Differential Differances
- blue fuel
- Biofuel appears to be scary stuff
- busted off glowplug
- Went to the drag strip
- Leak at T-stat housing
- Max crank case pressure spec?
