- oil burning?
- 92 f-350 7.3, many questions, smoke first
- Freeze plug replacement
- e350 6.9 engine bay clearances
- Transfer Case
- putting ford turbo on non turbo 7.3
- boost levels
- 6.9 Headbolts/studs
- Rear Brake Problem??
- Fuel Pressure??
- Hypermax Turbo VS. ATS wastegate Turbo
- Engine Light/Water in Fuel
- Finally Got-er Done!!!!
- headlight switch plug
- New Battery Information
- Need some info on 94 model truck.
- need clutch help
- turbo a 6.9
- 7.3l & c-6 vrv
- Torque converter
- clutch replacement procedure
- lift kit
- 3" duals or 4"pipe w/5" stack on idi turbo
- REAR main seal leaking bad need help
- Fuel and or air leaks
- my new truck
- Restoring 2 tired 7.3L diesels
- bus motor oil pan
- bluesh smoke when off accelerator
- Minor Oil Leak
