- Turbo worn out on 94 IDI
- No Start Issue
- Just wanted to thanks
- Fender Flares for 85 F-250 4X4 For Rusty Fenders
- Fender replacement on 1985 F250
- URGENT Question about 1989 F-250 7.3L Non-Turbo IDI Motor...
- 4.10 rear gear swap
- IP Timing
- New Member/Owner
- Where to get some guages?
- Injector line set
- GVW/Heavy load
- Front hitch on 87 f250?
- Long term turbo reliability
- Strange smoke
- replaced glow plugs
- glow plug relay?
- Front leaf springs
- 93 f250 front end shake
- Problem with 1986 F250 6.9 tranny or differential
- My 6.9 is running hot
- Leaking injectors
- Rebuild and modify ip
- I need your help - TPS and VSS - how to test
- Timing and seals
- Ip Timeing
- E4OD / Tach issue
- I want a body lift!
- TPS and VSS - whats wrong?
- My (unplanned) Body Lift
