- 1984 4x4 dually flatbed with 7.3idi
- ZF5 Buzzing Noise after SMF conversion
- E4OD suddenly not shifting into Overdrive
- High Pressure Oil Rail end plugs Large plugs
- Fuel line problem
- Anyone parting out a pickup in Western WA?
- Intermittent Knocking and engine shake at idle
- IDI in an 88 bronco
- Instrument Cluster instant failure
- 1994 7.3 Injector ?
- To-do list
- lost all eletrical power and wont crank
- 1986 6.9 engine drop into a 1987 f250 zf5 4x4 transmission
- 7.3 IDI Timing Tools
- GP fusible links burned up. Can I use inline fuses in a pinch?
- 1991 f350 7.3lidi coolant leak
- 88 f-350 need help finding part
- Tow Capacity Increase?
- Testing coolant for nitrate levels
- 4WD swap with brownie and PTO
- Seeking advice for overheated 7.3 IDI
- How complete is this turbo kit?
- 94 -7.3 IDI turbo Wire
- Hard brakes
- Where to find clutch master cylinder rebuild kit
- Am I expecting too much from my IDI?
- RABS brakes
- 7.3 engine swap into 6.9 truck?
- C-6 upshift
- 7.3 idi bus motor
