- Idle problems with 84 f250 (diesel)
- Injector crush washers
- 1994 f-250 7.3 turbo misfire
- Ball joints question
- Truck is uncontrollable going down highway?
- Plugged Wastegate
- 1994 interior plastic parts crumbling
- IDI/IDIT flywheel question
- rotunda 78-0100
- No start after ZF5 swap?!?!?!
- low oil pressure at idle
- upgrades to the van
- Alternator killing batteries overnight
- transmission compatability
- CL in northeast.
- transfer case
- motor idles rough when started
- Truck im interested in getting need opinions
- HELP ME!! Oil in Coolant! Oil Cooler-Head Gasket?
- Rockauto closeouts + 5% Discount code!!
- Lots of problems little time.
- Stripped Glow Plug Threads
- oil in the trubo
- Oil pressure
- Pesky Pyrometer Problems
- TIRES
- Drip Drip goes the power steering fluid
- 1 WIRE ALTERNATORS, HIGH OUTPUT
- Rev engine up, let off throttle, engine dies
- Oil and lube recommendations
