- Use RTV or high-tack on new intake gasket?
- My new truck
- panzer going on a diet to get in shape
- look what i found
- Fuel pressure question
- need diagram diesel fuel slector valve
- Tearing it down
- We've all been doing our pushbuttons wrong!
- engine light question
- Lift Pump - Bent arm/Long arm?
- Pulled Heads from 7.3 tonight and.......
- Does any one know what these parts are??
- Diesel Newb with a new truck
- tryin 2 turbo
- what is the value ?
- alternator question...
- new cdr ford only?
- Factory power specs.
- flywheel and flexplate sequence
- Side exit exhaust...
- 94 idi & 95 powerstroke
- 85 cab swap
- Fuel lines?
- 6.9 injector pump
- Spooling
- Need some advice!
- Random Downshift when not needed
- floorboard getting to hot up steep hills
- Is there a way to check
- ac clutch
