- smoke problem
- Water in Starter
- im just glad diesel is going lower n price
- Can I Swap an auto 94 7.3 into 86 standard INT 6.9, and then rebuild the 6.9 and drop it in 90 F250
- Pump timing
- Turbo Power?
- Banks turbo upgrade
- truck update
- 1990 Going Up For Sale
- Help! reading the fleetguard strip
- i have the worst luck
- zf4 or zf5?
- Couple questions - Oil Cooler and Glow plugs
- Check valve in fuel supply line? & other fuel ?'s
- Twin filter setup like AirDog
- N/A IDI CAI?
- 6.9 idi rebuild...HELP!
- Score on a 94 factory turbo parts or rebuild engine!!!
- '05+ Super Duty Coil Springs on 2WD IDI
- 6.9 Injector Pump R&R
- 1988 F250 7.3
- Intl. parts guy says IDI can't handle turbo.
- marker lights -- they are all gone
- Sound deadening on engine side of firewall
- Can we make a sticky that lists everything to look for when buying a truck?
- what are these connections? the saga continues
- How much is a '92 with a 7.3 worth?
- NEED WIREING HARNESS!!!
- Fuel Tank Selector Valve
- Oil pump?
