- Need dynamic timing performed in Houston
- Idaho CL ATS kit $250
- New '84 6.9 ATS Turbo 4-Speed 4x4
- CL-KC 30gal rear tank
- CL-KC 1982 Ford Tailgate
- Bouncing Rpms
- Off topic 3.8 Buick need a little help
- E4OD to ZF5 swap
- Transfer Case fill plug question
- How to check the health of my IDI
- Lift Pump Pressure
- Lift help
- saw a 93 f350 ccdrw 5spd for sale
- Initial start after IP/lift pump
- injection pump replacement
- New truck 92 7.3 5 speed
- dual 3" pipes into dual 5" stacks. need 3" mufflers
- Engine Block Ground Cable
- question about a tach sensor
- auto to standard?
- Good buy or not?
- Idle Sticking?
- Weak 1990 7.3 dually
- Rough Idle
- Elec fuel pump instal q's
- turbo on 6.9
- Differential Gear Ratios
- CL turbos - Idaho
- zf and t-case $300
- which trans fluid: 6.9 C6
