- 7.3 wire short
- 93 f350 7.3
- installing truck engine into van
- Foaming in the coolant.
- 92 and 94 7.3 wiring differences...HELP?
- tps ajustment
- wiring for fuel shutoff on 7.3 idi
- New project - no oil pressure. Scrap or fix?
- '91 dually starter replacement?
- 94 IDI died after 5 seconds
- Fuel filter change
- Reseal didnt go as planed
- 1984 f250 project.
- KOER test help
- Mechanical Temperature Gauge
- Sooooo stupid....
- Bad Crank turning..
- cold white smoke
- 6.9L w/ C6 Tranny & 4.10 axles even worth restoration?
- Oil pan leak ?
- 1994 7.3L IDI TURBO FUEL RETURN LINE ?
- Cam Issues -- Is this cam right?
- white smoke on start
- starter issue: manual or auto?
- How fast can a N/A 7.3 IDI do 0-60?
- 6.9 and 79 frame compatibility
- E4OD overheat - Did I push it too hard, or is something else wrong?
- How much "CLR" to clean rad and WTS issue???
- How to post to oilburners?
- 87-91 Diesel Tach Into Non-Diesel Cluster
