- Possibly broken glow plug in IDI 7.3 Turbo
- Advice on 87 6.9L to-do list
- tool bag.....?
- i need help
- Powerstroke Swap
- What are the wires that plug into the glow plugs called?
- Core/New pump in need of...
- anyone know Injector bore thread size??
- What is this and what does it do? Picture.
- OBS dash swap in your brick?
- 6.9L IDI Diesel Install in an F150
- e4od transmission not shifting
- Another air leak
- Still no Start, I'm stumped
- Freeze plug options on engine rebuild
- 1980-1997 easiest to keep going so many parts ?
- 7.3 piston question
- help! od light stays on and in limp mode
- 7.3 IDI 94 F350 Suspention bolt sizes.
- Turbo Rebuild
- 460 to 7.3 idi conversion FIPL question
- 1992 7.3 idi won't start
- Brake sludge
- starting a 6.9 that has sat
- Replace injectors vs just o-rings and return line
- Help... Now battery isn't holding a charge.
- Adjusted my TPS, does this sound right?
- '92 250TD 7.3 Navistar....stalling out
- Fuel Tank sending unit info
- What does the Vacuum pump do?
