- What's the deal with check valve in t-stat cover?
- 94 E350 non turbo. Starting to rev up while losing power. VID
- Glow plug question
- New Truck
- What is this?
- Fan clutch wrench size?
- Searching for vacuum pump and injection lines
- '90 F350 7.3 IDI Issues
- oil leak on 7.3idit
- No starting fluid or ether for hard start
- 7.3 locked up
- yet another O-ring Q
- Snap, crackle, pop when turning. I counted 8.
- Replaced my lifters (one broken) - Intake popping solved
- Buying a 300k plus 7.3 idi
- Need info for a rebuild
- Dually front wheel bearings (91)
- Another E4OD/FIPL question
- F150 Prerunner Suspension Work?
- FREAKING STRANDED AGAIN
- Quick question with random sensor?
- Looking for vrv for 1988 F350 vacuum regulator valve
- Heater hose
- Join me on my quest to build a reliable, affordable off road vehicle. (this should be interesting)
- New ferret and timing light
- 84 6.9 to 94 7.3 idi turbo swap.
- Thinking of swapping in a IDI
- 94 E350. Rattle while idling. Turn off, stat again. Rattle gone. Videos.
- immediate help. stranded!!!
- Delphi glow plugs
