- Installed Mishimoto Radiator - Leaking Transmission Everywhere
- 3G alternator acting weird
- 1985 6.9l rotor differences 6000 vs 8500 gvw
- RABS Problem
- need sending unit 86 f250 6.9
- New problem
- C6 to t-19 swap
- 85 6.9 runs for 4 sec then shuts off with the batteries completely dead
- Looking for the plate behind the water pump? What is it called?
- E-Pump Fuel Pressure Concerns
- 7.3 idi mpg seems off..
- What do ya think?
- relay identification
- Injection pump
- Wait To Start" light remains on after removing key
- 88 f350 rear anti lock brake light on
- Difference between 94and96 Front differentials
- Looking for Fuel Selector Valve
- Which TC on my 1989 F-350?
- looking at another IDI truck
- C6 shifting too early
- Runaway
- Radiator Core Bushings -- Polyurethane or OEM somewhere?
- Dana Super 60 Sawp
- Installed referbed Injector pump - timing: is static good enough?
- Balljoint Loose In Steering Knuckle
- 86 electrical problem
- Engine will not shut off when the key is turned off
- Can I run an electric oil pressure gauge & sender for a fuel pressure guage?
- Rough running motor when applying the breaks
