- Black Smoke After Changing Air Filter on '94 7.3L Turbo Diesel
- Looking to put a turbo on a 1993 7.3idi pre-turbo.
- Electrical
- Injection pump replacement, intake gaskets, and glow plug caps
- 1992 e350 diesel fuse #8 blowing
- electric fuel pump install question where do you tap into the ignition to turn pump on with key?
- Transmission
- Leaking line fittings
- Body Swap
- Main valve body issue
- Help!!
- Tach sensor rebuild
- cracked glow plug housing
- return line leaks / oring problems
- C-6 torque converter alignment
- Gear Vednors question
- White smoke nasty blue smoke
- How do I fix air into the fuel filter, truck only runs while schrader valve is pressed
- What is the maximum IP inlet pressure for the 7.3 IDI?
- Chuffing, Popping and missing Push Rod
- Should I Convert 1986 F250 Stock bed to wood Flatbed?
- Need Pics of Main GP wire Bypass
- CDR
- DynaMat
- 7.3 idi injector pump replaced and no start. willing to try anything....
- Newbie
- Injector Info
- Fuel leak at fuel feed line connection on injection pump
- 94 IDI Turbo 4:10 towing/ Change?
- Od, light flashing
