- Bulletproof Ideas, Needed?
- MODs Suggestions
- Need a price check and advice on engine
- Son+marker=ruined interior
- 6.0L Diesel #5 hydrolock
- Help!!!! Need a turbo on vail pass
- dos and donts for diesel trucks
- 2% fuel in oil sample at Blackstone
- 6.0 Leaking water
- HOT START ISSUES STILL EVEN AFTER IPR REPLACEMENT
- cab lights
- Considering an '05 F350 6.0l Dually. Tips?
- "Blue spring"
- It's a great time to own a Diesel (thanks Shell)
- Weird banging noise when cranking after head job.
- 06 F-350 oil leak
- camshaft position sensor troubles
- Studs
- Go fast stuff
- 05 Ford 6.0 Turbo Whooshing Noise... suggestions? VIDEO ATTACHED
- First Time Diesel buyer... HELP!
- Low Pressure Fuel Pump
- Fuel pressure on the Edge Insight ?
- Trouble with Pulsing...2003 6.0L diesel
- Starting to smoke a lot more
- Problems w/ EGR delete
- 03' ICP Oil leak fixed and bad hpop?
- Two piece heads what's the torque?
- Which wire controls dash light brightness
- Two wheel drive vacuum pump??????
