- DTC Help Needed Please
- Cut my losses? or hold on to it?
- '05 6.0 wont start at running temp?
- Well gentlemen its my turn for HG's!
- Boost issue
- Glow plugs
- 03 6.0 black smoke?
- Wrench Light, No Code !?!?!?!?!?
- Omaha, Ne get together
- low temp readings
- Engine Cleaning?
- 06 f450 6.0 no start no crank
- I'm buying myself a 6.0 motor!
- which head gaskets and studs or bolts.
- 6.0 swap done!
- 6.0 egr delete.No boost.
- IPR Removal
- Anyone running a Fumoto Valve and an FS-2500(engine oil)?
- F-350 coolants
- Fuel Pump Vacuum Leak
- Sinister coolant filter.
- 6.0 FICM?
- 04 6.0L Thud sound at idle
- EGR cooler weekend
- 05 6.0 surging turbo?
- Higher boost at running speeds
- Okay BISMIC, MCHAn, and the rest of you Diesel Gear Heads.....
- Need Help!
- I need 2 injector cores =\
- Light smoke at startup.
