- SuperChips 1805 and a weird smell...
- Check Engine Light!!!!
- Tuners and EGR...
- ECM chip mods on Ebay...are they for real?
- Where to tap for fuel pressure gauge?
- head gasket options for early 9-12-03 build
- Richmond, VA Diesel Mechanic
- brown smoke
- Fix for P0460 diagnostic code (fuel level circuit)??
- F250 SD Crew Cab does not start
- 2005 F350 6.0 no start
- 20,000 Miles with Royal Purple ATF.......NO PROBLEMS!
- Color of rear end lube
- Transmission Fluid Readings
- Axel Ratio?
- Truck seems to jump while turning slow
- Blue smoke
- Belt
- 2004 having issues
- Helping a Friend (Head Gaskets) pulling the engine etc.
- head gasket
- FICM or something else?
- Looking for starting circuit wiring diagram for 03 F350 diesel
- EGR Delete problem.
- Help Truck quit after running for 10 secs
- Emissions compliant EGR delete
- Tration Bars
- still learning
- Unpluged
- First Mod Done-Coolant Filter
