- coolant filter system recommendations
- Oil leak now lots of smoke and codes
- Winter front update
- Intake Elbow Boot Part #
- HELP dealer says stuck turbo
- Advice - looking at an 06 350 psd
- finally took the plunge. . .
- Thermostat stuck open???
- High-pitched whine under hood near front grill
- Stacks?
- odd turbo noise
- Arrgh, Ford owns Cummins,,,again.
- New to fords... Question about the 6.0.
- Overheat then chocolate milkshake time
- Coolant temp spike?
- Bad FICM and a good dealer.....so far.
- Spartan Tunes
- raising the idle (NOT HIGH IDLE MOD)
- coolant filter flow ?
- 6.0L Advice - Buy or Run
- Programmers
- Turbo Surge?
- Buying MBRP turbo-back exhaust
- egr and exhaust advice
- Remote Start + High Idle Mod?
- What are the correct towing capacities for a FX4 CC F250 psd automatic
- ABS Light comes on when on long drives?
- Oil leak.back plate? screwed!!
- How much coolant and distilled water do I need to do a complete flush????????????????
- itermittent problem when towing
