You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
RE 1065 F100 I'm sure I am not the only one who has done this, and probably someone may actually have the part number and name of the radiator hose I need. I have taken a 65 F100 V8 radiator and put it into the same that has a 6 cylinder, the V8 radiator has the water pump connection on the drivers side BUT the 6 cylinder water pump is on the passenger side, ANY help appreciated on the actual part number and brand of hose I need to hook up the radiator, if you have used such and it is for a different vehicle altogether please give me the info I need to get this thing on the road.
Thanks
I suppose it is too late, since you already have the radiator you wish to use, but I have found that a good radiator shop can build you anything you want, in any package you want, and for a very good price. The could probably even take the end cap off your radiator and put on on it that matches your application.
A long-assed radiator hose does not sound like an ideal solution.
__________________
Folks call me Bill. Why, yes, it is a 6 liter. Your jealousy is showing.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back (w/CAT),Edge Insight CS,Blue Spring,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto,'08 Diff Cover,Upfitters Retro-fit,Coolant Filter,Custom Man Steps,Keystone 2011 Cougar 278RKSWE,2012 Fusion SE
Thanks for your suggestion, I recently put a aluminum Rad in one of my 65s so I took the rad that was in and put in the one with a six, no need to waste a good rad, what I did was get a part from Summit that has a male end on each ends a a petcock in the middle, I used this to join 2 flex hoses.
