Pros and cons of not using a track bar - Ford Truck Enthusiasts Forums
Old 10-10-2010, 09:21 AM
monstertrucker's Avatar
monstertrucker monstertrucker is offline
monstertrucker is starting off with a positive reputation.
I just got done rebuilding my Dana 60 on my 1990 F250. I added about an inch of lift to my front (it already has 6 inch springs) while I had the truck tore apart. I have a drop bracket for the track bar for a 6 inch lift. Anyway, the track bar is now about a half inch too short. I talked to my buddy that owns a 4x4 shop and he said just eliminate it because the
truck has leaf springs instead of coil springs. He also noted that the track bar is half the length of the drag link, so it is not as effective as it would need to be on a coil spring system.
Has anybody eliminated their track bar on their solid axle leaf sprung truck? Will it put more or less stress on the frame and steering box without the track bar? Any opinions ,input or concerns appreciatted.
Rich
Old 10-10-2010, 10:47 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Mine is lifted 8" and i still have my trac bar
Now, with that said. I have heard of guys doing away with the trac bar with no issues and also guys doing away with it and having severe issues.
the way i look at is, if Ford put it on, it must do something
Old 10-10-2010, 12:06 PM
1966Tbird's Avatar
1966Tbird 1966Tbird is offline
1966Tbird is starting off with a positive reputation.
i heard this over on pirate4x4: if you don't run a trac bar in the front and you have shackles on the front of the springs you will wear out the bushings in the shackles because when you try to steer the truck the axle will try to move side to side
just what i heard
Old 10-10-2010, 12:32 PM
Quote:
just what i heard
That makes sense being the shacks are so narrow at the top and allow that much more movement
Old 10-10-2010, 02:56 PM
I have an Offroad Unlimited Shackle Handler kit in the front of mine which converts from the "A" style shackle to an "H" style shackle. That being said, I want the least ammount of stress on my frame and steering box. I think I will make me a new drop bracket or an adjustable track bar. Thanks.
Rich
Old 10-10-2010, 06:40 PM
Mudman's Avatar
Mudman Mudman is offline
Mudman is starting off with a positive reputation.
Most of the guys that have removed the track bar, have trucks with a front shackle reversal.
My 84 has a sky shackle reversal and I am still running a track bar. I have noticed that I need to install an adjustable track bar since my front axle is a little offset. Even with the track bar on my 35" tires (old and may have issues) I would develop a death wobble on certain stretches of road. Since then the roads have been improved and I am running 37's at the moment.
Old 10-10-2010, 07:04 PM
Quote:
Rich
Track bar drop bracket is just a flat piece of steel that bolts to the frame, then the trac bar bracket bolts to that
Old 02-23-2014, 09:45 AM
Shawn conard Shawn conard is offline
Shawn conard is starting off with a positive reputation.
track bar on 90 ford f250 4x4 with dana 60
How to adjust track arm?
Old 02-23-2014, 11:35 AM
f1504x4driver's Avatar
f1504x4driver f1504x4driver is online now
f1504x4driver has a good reputation on FTE.f1504x4driver has a good reputation on FTE.
The track bar is designed to eliminate side to side movement of the axle. While not required with leaf springs, it will prevent premature wear of parts and breakage. That is why Ford installed them. I would leave it.
Old 02-23-2014, 03:30 PM
Ok Im confused have leaf springs tho with a dana 60 swap so u dont need a track arm?
Old 02-23-2014, 04:06 PM
Quote:
If you have the originally designed narrow shackle, then YES
Old 02-23-2014, 04:08 PM
What would u consider narrow?
Old 02-23-2014, 04:09 PM
Its an "H" shape shackle in the front
Old 02-23-2014, 04:41 PM
So you no longer have the stock front shackle?
Old 02-23-2014, 04:47 PM
No there stock shackles with 4 " skyjacker leaf springs with dana 60 and 3" blocks on rear
track bar bracket ecampbell124 1999 - 2003 7.3L Power Stroke Diesel 4 03-06-2016 11:04 PM
track bar/bracket question ecampbell124 1999 to 2016 Super Duty 2 05-05-2014 09:38 PM
Adjustable Track bar! Andy Sullivan 1987 - 1996 F150 & Larger F-Series Trucks 3 04-11-2012 06:54 PM
Track Bar help on my EX. twisthappyr6 Excursion - King of SUVs 7 12-14-2010 08:54 AM
Do I need a track bar... freejay Offroad & 4x4 19 06-25-2008 01:19 PM
Tags
1987, 1990, 2000, 350, 60, adjustable, bar, bracket, dana, f150, f250, ford, inch, lift, track
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
