Pros and cons of not using a track bar - Page 2 - Ford Truck Enthusiasts Forums
Old 02-23-2014, 04:51 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Originally Posted by Shawn conard View Post
No there stock shackles with 4 " skyjacker leaf springs with dana 60 and 3" blocks on rear
YES, you have the stock front shackle
or
NO, the stock shackle has been replaced with something else
It doesn't matter what springs or block is in the truck
Old 02-23-2014, 05:00 PM
Shawn conard Shawn conard is offline
Shawn conard is starting off with a positive reputation.
So do I need the track arm or not?
Old 02-23-2014, 05:02 PM
You never answered the question.
Old 02-23-2014, 05:03 PM
Yes I have stock front shackles from auto zone lol
Old 02-23-2014, 05:07 PM
danr1 danr1 is online now
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
I wouldn't care what shackles I had stock or otherwise, I'd run a trackbar IMO its necessary it counters against steering forces.
Old 02-23-2014, 05:10 PM
Then YES, you NEED a track bar
Old 02-23-2014, 05:16 PM
Ok cool thank u bc I have the adjustable drop bracket. I was told just to loosen the nut from bracket and just let the weight of the truck find center and then tighten bolt . Its like a cam on both sides of bracket. Is that the right way to find center?
track bar bracket ecampbell124 1999 - 2003 7.3L Power Stroke Diesel 4 03-06-2016 11:04 PM
track bar/bracket question ecampbell124 1999 to 2016 Super Duty 2 05-05-2014 09:38 PM
Adjustable Track bar! Andy Sullivan 1987 - 1996 F150 & Larger F-Series Trucks 3 04-11-2012 06:54 PM
Track Bar help on my EX. twisthappyr6 Excursion - King of SUVs 7 12-14-2010 08:54 AM
Do I need a track bar... freejay Offroad & 4x4 19 06-25-2008 01:19 PM
Tags
1987, 1990, 2000, 350, 60, adjustable, bar, bracket, dana, f150, f250, ford, inch, lift, track
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
