2002 Ford F150 5.4 engine advancements? - Ford Truck Enthusiasts Forums
Old 10-09-2010, 10:59 PM
Cole F150 Cole F150 is offline
Cole F150 is starting off with a positive reputation.
Exclamation 2002 Ford F150 5.4 engine advancements?
Im a proud owner of a 2002 ford F-150 5.4 it is not the 7700lb package.
i was hoping some of you could help me figure this out. ive already replaces my coil packs twice now. but what i want to know is it safe to use the accell coil pack instead fords? an i want know make a list of things i can do motor wise of how to tune this bad baby up. for starters with ignition. throttle bodies, ex. anything you can think of that wont cause problems but simply make this motor to even better performance. "i do off road in the desert i have king arm suspension an i do have an automatic trans.
Old 10-10-2010, 06:49 PM
Hybris's Avatar
Hybris Hybris is offline
Hybris is gaining momentum as a positive member of FTE.Hybris is gaining momentum as a positive member of FTE.
From what I have read on the board over the years is that unless you are planning to go nuts with engine mods (Supercharger, head work, pistions, etc...) and race the truck as well then the Motorcraft coils are good for everything else.
Now as for stuff to make the 2v 5.4 more powerful I can name a few things:
Exhaust Headers and a high flow muffler as the stock system actually flows pretty well already.
Once the exhaust is done you might gain more power by adding a Cold Air Intake (K&N or Volant for example) but this is a hotly contested item on a N\A engine at least.
A Tuner like a Superchips or SCT X3 tuner (they're a site sponsor by the way.) will be good way to add power to the truck but in my opinion it should be a finishing touch so the tuner can take into a account all the other modifications done on the engine.
Don't bother with Throttle Body Spacers they don't do much of anything but lighten your wallet.
Replacing your crankshaft driven fan with a electric fan can free up power as well (I would suggest Troyer Performance's Dual 16" fan kit)
There are underdrive pulleys that you can get for the other various belt driven accessories but I can't say what it will do to the overall drive-ability of the truck.
After all this then the next step would be internal engine mods for this I would really start looking at Mustang parts sites like ModMax - 4.6 and 5.4 Modular Experts for example since more then a few 2v 4.6 parts will fit the 5.4 that is to say not all of them will fit obviously.
If I have made any mistakes please feel free to correct me.
Old 10-12-2010, 12:22 AM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Don't use ACCEL coils.
They are made in PRC and donot last very long before you have failures from shorted windings to open windings.
Been there!
The programs these trucks run on are very conservative to be sure the motors are 'tough' over the long term and not for full power they are capable of.
Other mfgers do the same thing.
Old 11-06-2010, 03:58 AM
Ok well im still having this hesitating response an a spitting jump feel when cruising on the highway. it was once a coil pack problem but now i think it can be my maf sensor, throttle body, or another sort of ignition. Help please ive ran out of ideas an to rule this one out. even when i first replaces my coil packs in febuary the engine light has never been on once but this painful sound continues. im open to ideas even small ones.
HELP with coil pack and plugs 2009 250 Tommy B405 1999 to 2016 Super Duty 1 08-05-2015 07:38 AM
Choosing Coil Packs Winning Windsor 1997 - 2003 F150 3 07-11-2015 10:06 PM
Spark Plug, Boot, Coil Pack Brand? OEM? sab2002 1999 to 2016 Super Duty 19 05-14-2014 10:55 AM
Coil Pack Pigtail Connector lizardman1 2004 - 2008 F150 1 09-20-2013 01:00 PM
how to change COP coil pack? scram98400jm 1999 to 2016 Super Duty 23 11-10-2005 05:03 PM
Tags
02, 2002, 2010, 54, advancements, codes, coil, cole, engine, f150, ford, mod, pings, power, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
