Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-09-2010, 09:14 PM
ah1988's Avatar
ah1988 ah1988 is offline
Garage is empty, add now
ah1988 is starting off with a positive reputation.
turbochargers and bio diesel
can you run bio diesel through a turbo charger no problem
was wanting to put one on my 7.3l idi to get better mpg
  #2 (permalink)
Old 10-09-2010, 10:26 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Both me and the guy I make with have 7.3's. His is an IDI and mine is a powerstoke. We have run 750 gallons so far...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #3 (permalink)
Old 10-10-2010, 07:46 PM
Sullid01's Avatar
Sullid01 Sullid01 is offline
Sullid01 is gaining momentum as a positive member of FTE.
I've been running b99 for almost 2 yrs (b50 for a few months in winter), at least 15K in my 6.0l w/o any problems related to the biodiesel.
__________________
Dan
2006 F250 6.0L Amarillo Powermax turbo, ARP studs, IDP RR, 4" Banks exhaust - turbo back with Cat and Banks muffler, Banks intercooler, CAT ELC, Dfuser coolant filter, Racor CCV4500, Hi Idle mod, harpooned tank, some big horns, Edge CTS, Isspro Fuel pressure and SCT X3 Matt (gearheads) SRL++ for powermax, DC Power XP270 alt
  #4 (permalink)
Old 10-10-2010, 09:22 PM
binuya's Avatar
binuya binuya is offline
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
It might be semantics. But if not, the biodiesel doesn't go through the turbocharger anyway so it wouldn't have any effect on the turbo itself. Being that you have an IDI however, there will be a few fuel lines you will eventually need to replace with Viton lines. The rubber lines will last through several tankfuls or more of biodiesel before they start to sweat, swell up,and soften.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
Tags
73, bio, biodiesel, dans, diesel, dr, ford, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
